XLT Center Console and Floor Mounted Shifter
The console started as a flow through that was converted to the standard center console. I changed the rear panel to the single 12v style without HVAC vents, added the front panel with cup holders and storage pocket, and trimmed the sides to match the front and painted the whole console a metallic black. It looks like the XLT console but didn't start out that way. The front transition needs a bit more work but looks ok as is. Cup holder inserts are included and two mounting brackets for the stock holes in the floor. Rear mounting bracket is factory, front bracket I made. I used my jump seat for a sixth person far too often to keep swapping them in and out. $225 shipped in the lower 48.
Floor Mounted shifter left over from the above console swapping. Moves through the range and can feel the detents in place. I never used it in the truck and cannot confirm actual functionality. $35 shipped in the lower 48
