instrument change question
before I go to the salvage yard has anyone changed out the instruments in a 94 f150 xl 4.9 for the nicer setup with tach?
I was shopping for a tach maybe digital on a sliding scale to fit on the column and thought it might be easier to put the right dash in.
Thanks for any advice, Cam
tonight is the fuel filter change i am dreading
Has to be from the right year. 92 and 93 will interchange. 94 and 95 will interchange. Some report having no problem putting a 96 cluster in a 94 -5, others have had issues.
You should stick with 94 or 95 to be sure.
Check the part # on the back of the cluster - the one on the plastic printed circuit - it should start with F4TE or F5TE - before you take it home.
