turn signals aint working???????
on
Looks strangely familiar...........
https://www.f150online.com/forums/el...-problems.html
Don't blame the GEM on this one, that most likely was you shorting the instrument cluster lighting to the GEM input for the signal return from the 4WD mode selector switch. That is a resistance only input that you applied power to.
on
Did you read the thread I linked above ?
this covered a possible problem with the MFS, take it out and test it. Nothing about the flasher.
If the hazards work, but the turn signals do not, the flasher is fine.
when checkin it when its out,may sound dumb but where do the red and black prongs go?
I also am having problems with my turn signals,I drive a f150xl.every now and then the turn signals quit.also the e-flashers quit working,i replaced the relay under the dash,now only the right side e-flasher works.and still no turn signals.now im a very patient guy,but this has me pullin the last hair i have out.please help.aaaagggghhhh
on
i have a 1979 f 150 wolfpack tuck my turn signals are not working it has the 1 big silver fuse and the turn signal master switch is making a conection i am compleatly lost some one help ---e-mail me some ideas sparky.edwards21@yahoo.com
sorry but you are wrong on your info... the hazards and the turn signals are on different flashers as a safety precaution so having one work doesn't mean the flasher isn't the problem
