How to fix the Leaking Rear Glass - Leaky Slider - Water Leak - Back Glass
Old 07-18-2003, 07:26 PM
Rockpick's Avatar
Moderator &
Okay, here's my quick 'HOW-TO' on removing the rear glass and taking care of the leaks that so many have had.
I've emailed this procedure out to NUMEROUS people and I think that it's been generally tried and true as I know it's worked.
It's a fairly simple procedure that involves REMOVING the rear glass and reapplying the butyl sealant that is used to seal the interior from the exterior.
It should be said that the design for the rear glass was changed with the 2002 models because of the consistent problems that they were having with them.
I am not responsible for anything that YOU do. This is a simple guide on how I removed my rear glass (to install a power slider). Do everything at your own risk.
Here goes....
First, go buy some butyl sealant. It comes in a roll and I think the consensus was to get the 5/8th size. NAPA and your local glass shop will have this.
Now, you're going to have to obtain access to the back of the window where it's bolted to the body of the truck. This can be done by removing all of the plastic moldings at the back of the trucks interior. Some of you will have to remove the bolts that hold the seat belts in as well.
Once you have obtained access to the glass, you will need to remove all 12 9mm bolts that secure the glass into place. Make sure that you hang on to the little brackets that are in place where you remove the bolts.
Once you have removed all of the bolts, now you must cut the old butyl sealant. I did this using a box cutter and a long bladed pocket knife.
Take the blade between the thin metal and the glass being careful to 1) not slice your hand open and 2) to attempt to get all the way down such that you are cutting all the way through the sealant. This is a critical step and, in my case, was by far and away the most time consuming. Be careful to not 'mar' the threads on the bolts that hold the glass with your blade.
Find the neighborhood kid and/or significant other and/or buddy to help you here. You're going to need to 'gently push' the glass back towards the box of the truck. If you feel that the glass is moving slightly however; won't budge, you probably have some more cutting to do on the sealant. I found it easiest to start on one corner and work from there.... individual results may vary.
Push the glass back to your friend being VERY careful to not bend the frame of the glass. DO NOT USE EXCESSIVE FORCE!!
Once the glass is out, clean off all of the butyl sealant from off the glass and around the pinch weld (portion of the truck where the glass meets the truck).
Use the butyl sealant that you had purchase prior to starting and bead the sealant around the glass staying on the outside of the 12 bolts.
Replace glass and resecure all 12 bolts using a 'back and forth' motion to tighten them evenly.
BEFORE replacing all of your plastic, take it around and hit it with some water. Make sure you don't have a leak.
If all is well, replace plastic, do a little dance, and be thankful that it's fixed. If you've still got a leak, repeat the procedure or pay a glass shop to take care of your problem.
Best of luck and feel free to email me with questions. rockpick@f150online.com
Also, I welcome any additions or suggestions to this procedure as I'm sure it's not totally complete.
RP
**Edited to replace old email address**
Old 07-18-2003, 09:27 PM
pjf77's Avatar
Very informative and detailed!!
Old 07-27-2003, 11:43 AM
01 XLT Sport's Avatar
RockPick, excellent "How to" post...
Old 09-30-2003, 08:47 PM
lifeguardjoe's Avatar
Brown noser
Old 10-01-2003, 08:20 AM
Rockpick's Avatar
Moderator &
Originally posted by lifeguardjoe
Brown noser
Teenagers....
Old 10-01-2003, 11:24 AM
FrankLee's Avatar
First, go buy some butyl sealant. It comes in a roll and I think the consens was to get the 5/8th size.
How long is a roll? Is one roll enough?
Will this procedure work on a slider window?
Thanks.
Old 10-01-2003, 12:44 PM
Rockpick's Avatar
Moderator &
Frank,
I'm honestly not sure how long the roll was but the ones I've seen were adequate length. What I would do if I was you is, before I go to buy butyl sealant, I'd do some rough measurements across the window and check the package for length to make sure you have enough.
The fix that I've described remedies the leak AROUND the outter edges of the window and not necessarily the single pane of glass that slides left to right. In short, I'm referring to the glass as a whole rather than an individual portion of the glass.
RP
Old 10-06-2003, 08:13 PM
97f150f/s's Avatar
Great how-to RP! I tried to fix mine last fall. I got it almost completely out except for one spot that was stuck. I tugged a lil to hard and cracked the frame in that spot. Now I have masking tape around the top to keep it from leaking.
PS....Did you ever get those yellow foglight bulbs?
Old 10-06-2003, 09:12 PM
Yankee7985's Avatar
I took the "less agravating" route, paid an auto glass shop $212.00 to replace mine, and got a warranty to boot.
Old 10-06-2003, 10:29 PM
Rockpick's Avatar
Moderator &
Nope... I went to Silverstars... *shrugs*
RP
Old 04-26-2005, 12:07 PM
tmorris1's Avatar
I just had a local glass shop remove and reseal my rear window and he only charged $35. He said he does a lot of Fords with leaking rear windows. Everything is leak free now and you can't beat the $35 price tag.
Old 10-13-2009, 07:30 PM
gerrytseng's Avatar
I just replaced the rear window sealant for my '97 F150. Once I removed the rear window frame I could see where the leak was coming from as the sealant in that area didn't appear as solid as the rest of the contact areas.
While it wasn't too aggravating to remove the plastic panels and headliner it was tough finding a last-minute store who sold an appropriate sealant. I wound up finding one at a KOI auto parts store, the seal specifically being 3M Round Bead Ribbon Sealer Auto Glass Replacement Kit (3M Part #08611). The 15 foot roll was more than enough and had some left over. So yes, it would be a good idea to buy one before you start this - worst case you can return it if you wind up not using it.
When scraping off the old seal from the rear window frame it appeared to be similar to the 3M product. I'm sure a foam core butyl tape would virtually guarantee a leak-free result but I didn't have time to order it with the truck in the driveway with the rear window removed and rain coming tomorrow.
Total cost was <$15 for the ribbon sealant and about 3 hours to remove and get the rear window bolted back on. I haven't yet reinstalled the headliner and plastic interior panels so that I can check for leaks in tomorrow's rain pour.
Old 10-15-2009, 09:33 PM
Rockpick's Avatar
Moderator &
Hopefully, the write up helped just a tad... I hope it doesn't leak anymore on you!
Old 10-30-2009, 10:53 PM
mete's Avatar
Whatever happened to using silicone rubber to fix leaks ? It's been used for many years without removing the glass.
Old 11-01-2009, 03:50 PM
zing77's Avatar
Would this procedure also apply to the 2004-2008 F-150? I have a leak that I assume is coming from the back window in my 04.
Quick Reply: How to fix the Leaking Rear Glass - Leaky Slider - Water Leak - Back Glass
