What does the Line mod valve do?
The line mod valve increases line pressure in the trans, for firmer shifts. They install by removing the trans pan, then the accumulator valve body. remove a spring clip to access the valve. Mine goes in this weekend! Lloyd
2000 Black L Airaid & Superchip R9. Drag Results: Best ET: 13.07 Best MPH 103.09 Best R/T .501 (twice) Best 60' 1.631 on F1's. Mods to come: JDM 90MM MAF, JDM 2# lower pulley, JDM Oval TB, JDM Line mod valve, JDM Flip chip steet/race, PSP Electric fan kit, M/T ET streets, Drive shaft loop. I thought I could be happy with a chip & filter, but NO! 1973 Cutlass Supreme 455/450HP 4 speed. Too many Mods to list! 95 Olds Aurora 91 S10 305TPI/700r4 project 2000 freightliner FL60 Rollback tow truck My garage overuneth.
MODERATOR OR ROAD KILL AT www.svtperformance.com
John893,
If you do buy one and deceide to install it yourself I would suggest you go to somebodies elses home and use their garage or driveway. That way when you dump 5 quarts of trans oil when you remove the pan it doesn't make a mess in your driveway or garage.
John Armstrong
2000 Red Lightning
#444 of 4966
Born 2/22/2000
Went home 3/6/2000
John Armstrong
2000 Red Lightning
#444 of 4966
Born 2/22/2000
Went home 3/6/2000
I did my JDM line mod valve this past Sat. Just like LSchicago said, I would only add pulling out the filter. It just pulls right out. I think it was 8mm bolts with a couple 10mm nuts. It was real easy and it shifts alot harder. I had my JDM chip burnt with this mod, so I think you need to get your chip burnt for it.
Bill
'00 white lightning-#2030 of 4966-4/6/00 thursday
muth mirrors,door key pad mod,fog light mod,
clear corners, super white; headlights,corners,fogs,
trenz billet upper and lower grills, billet 3rd brake light cover,
Bedrug, harley davidson tonneau cover,
JDM flip chip, JDM lower pulley, 90mm mass air, JDM tranny mod,
JDM 5"aluminum driveshaft,
J.L. stage 2 ram air kit
BellTech 3/4 lowering kit
2001 tails installed
20" chrome lightning wheels on order
more to come....
my zing albums-_-click here-_
'00 harley davidson FLSTC tons of custom parts..
'99.5 nissan pathfinder le-STILLEN EQUIPPED
'88 toyota show truck(TONKA)
'91 toyota mr2 turbo (to many mods to list)
'00 yamaha banshee(toomy race kit/chrome pipes)
I sell a kit that is a remanned accumulator with upgraded shift springs and line modulator plunger valve. No guess work on dropping the wrong body, losing case *****, tv ball and spring etc..., for a few dollars more I include the deep plugged pan and a new filter, the pan and filter are Genuine Ford Parts, the springs Tricumulator and the modulator is a Sonnax Valve. Whole thing goes for $100 for the accumulator ($75 exchange on the core) and $50 extra for the pan and filter. The pan and filter alone will run you over $70 at your local Ford Dealer, so I think it's a great buy, myself.
