Bassani Installation Notes, Pics, & First Impressions
Old 02-05-2002, 08:16 PM
BMWBig6's Avatar
Talking Bassani Installation Notes, Pics, & First Impressions
I know I asked a lot of questions before I bought my Bassani. But now that I've taken the plunge, I figure I'd return the favor and share some of my experience with you all. Please be patient as there are lots of images that need to load...
First, if your truck has any miles at all on it, budget a good half hour the get the dang stock muffler off. Mine was already replaced once by the dealer only 1000 miles ago and it was practically welded on by the time it was time to come off. Had to coax the thing off with a little heat and an enthusiastic mallet. Was considering saving the stock exhaust in case I wanted to return it to OEM later, but a couple swings with the mallet put those plans to pasture:
Here's the "old" stocker. Not a bad unit.. just a little too pedestrian for something as bold as a Lightning:
Another view:
Old 02-05-2002, 08:22 PM
BMWBig6's Avatar
Now let's see what Santa brought:
Inside the box you will see 3 boxes: one for each muffler, and another for the X-pipe. The fasteners come in little baggies, and you get a little disclaimer sheet with warranty info and 2 pages of instructions (text and photos). The clamps are kind of floating around in the box so don't lose those. You also get 2 cool stickers. NOTE: Bassani has changed the sticker design to this new style - the old style were silver letter cutouts that looked a little better on the window glass.
I recommend you leave the bubblewrap on the exhaust tips to keep them scratch-free while you are aligning the exhaust later.
Here's a close-up of the x-pipe.
Old 02-05-2002, 08:24 PM
DB's Avatar
DB
DB is offline
Great pics!
I've gotta get me one of those....
Old 02-05-2002, 08:33 PM
BMWBig6's Avatar
OK, now on to the installation. Sorry I don't have any in-between shots (I was busy dammit) but here are some notes I remember while putting the new sucker in:
1) Feel free to toss the old rubber hangar donuts as you won't be using the factory hangars anyway.
2) When installing the new hangars, PAY ATTENTION to the photo instructions - it's very easy to put something in backwards. No I'm not an idiot but at 3 AM anything is possible.
3) Do not lose any nuts. (goes without saying)
4) If your L is lowered, you may need to find a different way to mount one of the hangars... see other board members for info on this.
5) The 2.5" spacers supplied in the box are too LONG! Or the bolts that go inside them are too short. Either way you'll need to cut down the spacers or discard them althogether for something else (like stacked washers) to get enough threads above the frame rail when installing the biggest hangar. This will seem vague to those who never installed one of these, but if you've done a couple you know that Bassani gave us the wrong size parts and a little customization is necessary.
6) Do NOT tighten anything until the whole exhaust is in place. That way you'll be able to align everything properly.
7) If your lift arm was in the way like mine was, by all means lower your L, move the arm, and lift it again. You may not be able to line up the mufflers properly otherwise.
8) Bassani has changed the clamp design yet again. They used to furnish U-bolts but not anymore. Use whatever you want, but tack-welding is probably recommended for the highly modded L's.
The finished results:
Old 02-05-2002, 08:34 PM
BMWBig6's Avatar
Take the bubblewrap off the tips BERY KERVULLY!
Old 02-05-2002, 08:36 PM
HIGH ROLLER's Avatar
Thumbs up Awesome Sound
I just installed my new Bassani catback yesterday and i am very very happy with the sound and performance it gave my L ,it compliments my new stepheaders in a very big way!
Matt
Old 02-05-2002, 08:39 PM
BMWBig6's Avatar
BTW, the new Bassani exhaust tips have the logo stamped or engraved on each tip, while the older ones do not (nyuk nyuk nyuk):
Hopefully when you're done everything is lined up properly and you only have a couple washers left over.
WARNING: Exhaust will STINK like Dana Stubblefield's cleats whenever you drive it for the first few days.
NOTES: I noticed my Bassani was almost SILENT at idle - it barely even hissed. But my friend's Bassani has got a couple thousand miles on it and he has a nice rumble at idle. I'm not sure if Bassani changed the design or sound characteristics of the exhaust since he got his, but I imagine that the whole thing gets a little louder (meaner) with age as its broken in.
Old 02-05-2002, 08:51 PM
BMWBig6's Avatar
Thumbs up
So how do I like it? I LOVE IT!
The SOUND: I was suprised as how quiet it was at idle (although I do expect it to get louder). At around 2000 RPM the crecendo will fill the cabin, and the blower wine is being overwhelmed. Briefly visiting 3000 RPM, you're roaring down the road and it never stops after that. Let off the gas and the exhaust note changes and bubbles a bit . It drones a LITTLE bit when going up hills at partial throttle at cruising speeds, but coasting is absolutely silent (for now). It only comes to life when you put the pedal down. The exhaust doesn't seem quite as deep as before, but it's definitely LOUDER and has a nice aggressive note. It's not harsh at all, which I like. I am very pleased with the sound, but unfortunately the factory stereo is having a hard time keeping up.
How does it FEEL?
Well, I don't notice any loss in power, and the L still takes off with the same grunt as it used to. But it does seem to stay alive a wee bit longer in the higher RPMs. This could all be psychological of course, and I haven't calibrated my butt dyno to SAE specs in weeks, so take this with a grain of salt. I have to say it does seem just SLIGHTLY stronger, like it's holding the power band a little longer and higher than before.
Was it WORTH it?
IMO, yes. The craftsmanship is super, and almost everything fit perfectly. Took an hour to install and the only hold-up involved adapting the spacers. The tips look great and really fill in the side skirt opening well. And the sound.... WELL TIME TO GO FOR A RIDE!
Ok, enough bandwidth for now...
Old 02-05-2002, 08:53 PM
Silver-Bolt's Avatar
Great post.
Old 02-05-2002, 08:55 PM
DaveRed99's Avatar
nice
let them break in a little ...... =0D
Old 02-05-2002, 09:03 PM
Chikenears's Avatar
Thumbs up Ben
I'm totally impressed with your post. I bow to the King! Great Post!!
Your sound will improve slightly in no time, a week at most. Mine likes to give a slight glasspacky sound when backing down in third gear. Not much and no popping like glasspacks. Just a nice rumbling pop. Terrible description, I know, but other than that I'm at a loss for words. It just a unique sound.
Super pictures too. If we had everybody to post quality pictures of installs like yours, we would make this community a better place.
Chikenears
Old 02-05-2002, 09:18 PM
SLVRLTNG's Avatar
OK Ben,
great post, looks great. I may have to check into this mod myself, tax return on the way!!! now the real ??, is it real or is it memorex???...................JR
Old 02-05-2002, 09:37 PM
whitetoast11's Avatar
I had 3500 miles on mine when i took my stock exhaust off,, all you gotta do is pull on it w hile someone else wiggles it in a circular motion came off as if it wa buttered,,, i too had the wrong spacers sent, but used just a simple pipe cutter and accurate measurements to cut them down to size. These pics are great for an install as the instructions although they are good, the black and whit pictures stink. One other note though,, my bassani seemed t be louder before it was broken in, not a better sound then now, but just a bit louder before.
I also notice the better driving at higher rpm's, it seems to really apreciate the exhaust at higher speeds,, practicly no difference at all at the low end though. I dont think its psycological either, i've had friends in the truck who i hadn't even mentioned my new exhaust and they'v said it seems to drive better on the freeway as well. great pics,, we should use them for a do it yourself page n installing this exhaust. As said before,,, the instructions really have crappy pictures.
~Toast
Old 02-05-2002, 09:42 PM
ICULOKN's Avatar
Those strap clamps SUCK!!! I blew mine off twice with them even after impacking the hell out of them!!! Change to the U-Bolt style for sure!!!
GREAT POST!!!
Old 02-05-2002, 09:43 PM
the doctor's Avatar
BMWBIG6, heres a question for you,,, uummm,, why is your stock muffler, well, PURPLE???? No wonder it was welded on! That baby looks like shes been HOT a few times! Had your foot in it a bit I see.lol Looks great, nice job on the post, I know someone who will benefit from this!
Quick Reply: Bassani Installation Notes, Pics, & First Impressions
