Switching from Mercon3 to Mobil 1 Synth. in Trans
I have a quick question. I did a search but couldnt quite find the info I wanted. Ok I want to switch to Mobil 1 Synth. in my transmission which way is better just pull the pan and the plug from the converter and let it drain or use the tranny flush machine that tee's into the trans cooler lines. The machine would be faster but I think the fluids would mix is this wise? I know its not MerconV so I am not that worried. Just Curious any help is apperciated.
Greg
Greg
NO SUCH THING AS MERCON III
You guys have really got to start and pay a little more attention to your manuals if you are going to do your own truck work or give out suggestions to other people. The atf used in our lightnings from the factory is MERCON. I have had Redline high temp atf in my truck since june and, I have heard of other guys using the Royal Purple atf all without any problems. The dealership changed the atf in my truck (didn't have anything to catch the 16l) and I believe they just drained the pan and convertor. I don't think this method would be as good as using the pump for getting all of the old oil out but, the pump would require more of whatever atf you are using in order to flush the old oil. Don't mean to sound like I'm preaching but before you give someone suggestions on what to do make sure you know what you are taking about.
I didn't really say not to use synth fluid, I said I don't. As far as Mobil 1, I know an engineer who says it's the best stuff to use, hands down, so it'll work, and some people like it, I don't, but mostly because of the price, not because it won't do a good job. Now what I did say, is don't use MERCON V, the fibers will unravle in it is what I'm told, but I know it's a big no-no.
G
G
