Painted or powder coated calipers
Long time listener first time caller. Just got my 2001 L and ordered my 20 in
chrome wheels and my 1/2 drop. Would like to do something about the caliper color. my truck is red. I
talked to a guy that does powder coating and he said because of the heat that I
would have to take the whole brake set-up apart that would include taking the pistons out and just give him the cast. I do not want to do this. Any suggestions? I do not no if paint will work with the heat. appreciate any help.
I painted my calipers red to match my truck about 4 months ago with a special brake paint that probably is an epoxy two part system. It drys in 6 hours and is fully cured in 3 days. It has a glossy finish and has held upwell. Here is the web page and e-mail to contact to order paint. I only need one kit to do all four calipers.
Web page: http://www.mgracing.an/caliperpaint.htm
e-mail: jsmajzun@netzero.net
I painted the callipers on my red firebird yellow. I did not know about powder coating at the time. I just used 500* engine paint in a spray can. I put a plastic bag and newspaper around whatever I did not want painted. After about a year, the paint started to chip, and they were VERY hard to get clean. I too would like some info on powdercoating. Anyone done it? How much does it cost, does it last, where can i get it done at???
Justin
Justin
I did this to my ranger before,,, its very very easy to do. All you have to do is take the calipers off yourself and use engine block paint,,,, its not as glossy of a finish, but it holds up very well to the heat and the wear, it wont chip and grease doesn't show as easily. Plus its only about 5 bucks from any auto parts store. When i first painted my calipers on my ranger i had no experience at all with auto work, and was able to do it no problem after talking with a friend who is a mechanic. plus if you ever need to clean it you can use starter fluid,, i found that worked very well. My only problem was i wished it would have been shinier
Thanks for all the responses. It looks like I will go with the high temp paint.
crazyfoo- The guy told me it would only be about $75.00 to powder coat all 4 calipers.
I was all happy until he told me about the dismantling I would have to do.
Malibu-Not tom but mike and the mad dog sports show.
I painted mine as well...
I purchased "Caliper Paint" in red from an auto accessory website about 9 months ago and painted my calipers. The paint came in a small can that only coated the front calipers. I went to Auto Zone & purchased a can of 500* engine enamel and completed the job, even adding another coat to the front calipers. I prepped the calipers with a wire brush, then used paint thinner on a shop rag to clear any grease or dust. I used newspaper & masking tape to cover the rotors & undercarriage & put my cover on the truck (probably not necessary), to keep any overspray from settling on my exterior paint. The calipers looked great with my black L for about 8 months then the brake dust began to accumulate, and they became hard to wash and lost there original luster. So..., I repeated the process last month using a brush & alcohol to prep, leaving the previous paint intact & they're shiny again. The whole process, using a 3-ton roll around floor jack, in my driveway took less than an hour each time, the paint dries very quickly even if heavily applied and is very eassy to work with. Good luck.
There is a guy in my warehouse that does powdercoating.He is a perfectionist. Champion porshe ( largest porche dealer in the U.S. ) liked his work so much , that they now give him all of their work.He is a small operation.He does dismantle the calipers himself (no big woop) .I am just debating if I should go with silver or red on my red 2001.
