Pics removing the hitch safety hooks
Old 04-24-2000, 11:05 PM
Peter B's Avatar
Post Pics removing the hitch safety hooks
After removing the receiver hitch, it still didn't look that clean w/the safety hooks, so here's some pics of how I removed them.
Now, use a diegrinder to carefully remove.
Finish up using a 4" grinder w/60 grit flapdisk
Ahh, much better
[This message has been edited by Peter B (edited 04-24-2000).]
Old 04-24-2000, 11:25 PM
Silver_2000's Avatar
oops he fixed it while I was trying to help..
Doug
[This message has been edited by Silver_2000_! (edited 04-24-2000).]
Old 04-25-2000, 02:21 AM
BadDog's Avatar
Ooh. That's like watching someone castrate a bull. Nobody's taking a grinder to MY baby!
Regards,
Gordon
99.5 Red Lightning
Only driven on Sundays (1/4 mile at a time)
Old 04-25-2000, 09:32 AM
JoeLightning's Avatar
Thumbs up
Very Nice Peter!
Had a great time last Friday. Last night I looked under the rear and contemplated doing the same .... and now here is your post that you've done it. My grinding disk was worn more than I thought, and I discovered my supply was out as well. O well, a trip to the Home Depot this week will solve that tab problem. I noticed you're using the 'flap disc'. I discovered those this last year and man do they work fast. So what did you use to paint the ends after the grinding????
Joel.......
99.5 White Lightning,
SVT # 0056
[This message has been edited by JoeLightning (edited 04-25-2000).]
Old 04-25-2000, 10:30 AM
Peter B's Avatar
Cool
Joel,
Just your basic Krylon semi flat black. Yeah, aren't those flap disks incredible.
Old 07-07-2000, 01:06 PM
'00BlackLightning's Avatar
Peter B
I haven't looked at my L yet but I noticed what appears to be bolts by the tabs you were grinding. Are these to hold the tabs and can they be removed this way?
I would rather not grind the tabs off. Besides, I guess I could always hang a foxtail or something from it. hehe
2000 Black Lightning, Snuglid, Custom Bed Carpet, Clear Corners, Lightning banner, Tinted Windows, Custom air intake, 2" drop.
delivered Apr 6. NLOC #377
Old 07-07-2000, 02:07 PM
'00BlackLightning,
The bolts hold the bumper cover on. The tabs are welded to the bumper frame and require cutting if you want to remove them. I cut mine off the day after Peter did his photo shoot. Looks much better without them. My justification for jettisoning the tabs is that if I ever tow in the future, I’ll replace the hitch, which has integral tabs on it.
Good luck! You’ll feel much better after you’ve finished.
Joel.......
SVT # 0056
Old 07-07-2000, 06:41 PM
DreaminAboutL's Avatar
Question
Is the tow hitch as easy to remove as it looks? I.e just remove all the bolts? Is there anything tricky?
And how much does the hitch weigh (approx)?
Thanks...
Old 07-07-2000, 06:53 PM
jack77's Avatar
Dreamin'
Yes, it is very easy and it looks much better when your done. I seem to remember someone who put the hitch and bolts on a scale and it was 50 lbs.
White 1999 Lightning
Build Date 7-26-99
#2892
Snuglid
Bedrug
Superchip
Member NLOC
Quick Reply: Pics removing the hitch safety hooks
