RedLine's response to oil change
Following is RedLine's response to my e-mail regarding when to change to synthetics.
___________________________
We recommend waiting long enough for the rings to seat before starting with
the Red Line motor oil. This will typically happen before 1,000 miles, if
you wait a little longer closer to 2,000 miles most of the initial wear
will have taken place and be out into the oil and filter. At 3,000 miles it
is certainly safe to start using the Red Line motor oil, I would recommend
the 5W30.
jim@jimshaw.cc www.cars-n-trucks.com/lightning.htm
Black 00, Superchip, clear fronts
Airaid, chrome wheels, AIM 2" drop shackles
Super whites
2000 E320
1993 Cobra R
1959 Corvette
1949 Plymouth
Looking for a better paying job to support my L
[This message has been edited by FORDSALES (edited 05-23-2000).]
the 5W30.
Super whites
2000 E320
1993 Cobra R
1959 Corvette
1949 Plymouth
I'm working on a Redline dealership for a client of mine. If successful you will be able to buy as the "Lightning Group" at a discount. I believe the retail on Redline syn oil is about $7.75 a quart. They also make other great products like Waterweter, a great additive for your radiator and intercooler. My sole interest in the deal will be to secure these products for myself and others in our group who would like to buy them at a discount. I will be receiving no $$$ out of the deal. I'll keep you posted.
noelvm
noelvm
noelvm
That is great. That is why I am doing the group buy on Autophysics filters.
I hoped you would see this post. I knew you'd like it.
jim@jimshaw.cc
Super whites
2000 E320
1993 Cobra R
1959 Corvette
1949 Plymouth
jim@jimshaw.cc
Super whites
2000 E320
1993 Cobra R
1959 Corvette
1949 Plymouth
My local auto parts store sells Redline for about $5.99 per quart. The Mobil 1 they sell is just a bit cheaper.
Here's an interesting comparison between Mobil 1 and Redline http://cjsupra.kendra.com/oil-spec.html .
RedLine's response to my e-mail regarding filters for their syn. oils.
________________________________
There isn't a need for a special oil filter with the Red Line, we just recommend a good quality filter, I like the Wix filter.
__________________________________
jim@jimshaw.cc
Super whites
2000 E320
1993 Cobra R
1959 Corvette
1949 Plymouth
jim@jimshaw.cc
Super whites
2000 E320
1993 Cobra R
1959 Corvette
1949 Plymouth
I sent an email to Chris, the guy that is doing the test on oil at the site in STROHM post above. He sent back a very nice response to several questions which I will post in part here.
1. Have you done any tests on the longevity claims of synthetic oil for extended use.
ANS: Just about all synthetics out there of any decent quality will safely go 10,000 miles. The biggest consideration here is the fact that dirt, deposits and generally the crud that your oil holds in suspension away from the metal parts in your motor are the things which force oil changes...usually way before the oil itself wears out. Yes, oil filters will catch a lot of this (over a certain micron size...and depending on the quality of your filter), but not all of it. So, essentially, after a while, I guess the best analogy would be the filter keeps the equivalent of large grit sandpaper from acting on the bearing surfaces of the motor, but past a certain point, there's still some fine grit action in there after a while. This is partly why the oil gets black.
The other factor is the oil oxidation and TBN(TOTAL BASE NUMBER). Oil oxidizes with exposure to air (just like anything w/ metal bits in it) and you can see on my charts just how much the percentage spikes when I simply topped off a little from an already open container. Makes you want to always use fresh stuff. TBN is simply a measure of the oil's additives. I did this on the baselines to compare with specs from Mobil and Redline to see if they were on the money (they were).
(me...on his chart he is changing his oil at various intervals. He ran the Redline several times for 3537 and 3582 miles. He has run the Mobil 1 Tri-syn 2503, 2659, & 2561. He admitted to being rather **** about changing his oil).
2. I asked additionally about why he liked the Mobil 1 tri syn over the Redline.
ANS: Yup, I like Mobil's new Tri-Synthetic formula over Redline, hands dow. I used to be a pretty solid Redline devotee, but after seeing the fact that wear numbers were half as much, I couldn't wait to switch. This has been corroborated by a similar test on two different Mustang 5.0 motors too. (by a mustang group guy. He came to the same conclusion.)
Don't get me wrong..both oils are very good, but Mobil 1 seems to be better and hell, it's also cheaper to boot....
I didn't read this until I got home, but I stopped in Super K-mart today to pick up some stuff for my wife and they had Mobil 1 Tri-Syn on sale for $4.00 QT. Bought six and put in today. 10W30 (Sorry Ford. It's already over 100 degrees and I just couldn't do the 5W30). I turned 20K on my L today.
noelvm
EDITED 8/13/00--After intensive additional study I have come to the conclusion that my concepts of oil's behavior in an engine are not relevant for synthetic oil. Quite simply it does not breakdown like regular oil and indeed does not breakdown at all. I am going to run the 5W30 and no longer worry about it.
noelvm
[This message has been edited by noelvm (edited 08-13-2000).]
noelvm
noelvm
I read Strohm's post-reply and went to
to look over the tests. It looks like I will also go to Mobil 1 and change my oil to syn. at the next change which will be at 4000 miles
Super whites
2000 E320
1993 Cobra R
1959 Corvette
1949 Plymouth
[This message has been edited by FORDSALES (edited 05-24-2000).]
Super whites
2000 E320
1993 Cobra R
1959 Corvette
1949 Plymouth
Thanks STROHM. This is the first techinical data on comparisons of syn oil I have seen. While most of it is over my head, it would appear the tester considers Mobil 1 tri-syn the best with Redline second. It appears he is changing oil every 2000 miles which doesn't really address many of my questions. I am going to try to email him.
The best regular price I have found for Mobil one around here in Houston is at Target $4.50 qt.
noelvm
noelvm
