ASP blower pulley
ASP blower pulley
Picked up the ASP blower pulley and puller yesterday. Went to their shop in Stafford, Texas. They did not know if the puller worked on the Lightning blower because it was made for the Grand Am one. Hopefully I will have a chance to install it this weekend and post the results.
They gave me $40 off the entire deal, guess because I went and picked it up personally.
Jerrod Gross
99.5 White Lightning
#1414, May 19,1999
Snuglid, sprayed on bed liner, 8.84sec/79.8mph (1/8th)(before mods.)
SHM mass air/conical filter & chip
Jerrod Gross
#1414, May 19,1999
Got the pulley put on. Two man job. It is a close fit on the snout of the blower. Had to back it off just a hair for clearance. Does not jack with belt alignment. Gave me approximatly 2lbs more of boost. You can feel it!
If anyone in the Houston area decides to buy their pulley, they can borrow the puller that I bought. Save you $160.
Jerrod Gross
#1414, May 19,1999
Jerrod Gross
#1414, May 19,1999
Yoda,
Took the chip out over the holidays, was getting some detonation. Need to send it back for adjustment. No detonation with the filter and pulley.
Jerrod Gross
#1414, May 19,1999
SHM mass air/conical filter & chip, ASP blower pulley
Jerrod Gross
#1414, May 19,1999
Metallic Blue,
The pulley replaces the existing blower pulley. The puller pulls the pulley off and pushes the new pulley on. ASP sells the puller for $160 online, pulley is $110. The installation time was about an hour, but if I had to do it again, probably 30min. The instructions with the puller show how to set it up (although they are for a Grand Am). It's pretty much pull it off, reverse it and push the new one on.
As I mentioned earlier, the pulley is a tight fit, had to back it off just a hair for clearance. Belt alignment is still cool and their is no rubbing. Just hard cranking that press-fit pulley on and off.
Jerrod Gross
#1414, May 19,1999
[This message has been edited by 99SVT (edited 01-09-2000).]
Jerrod Gross
#1414, May 19,1999
Mettalic,
Yes they do. http://www.autospecialties.com
The pulley is under "Street Pulleys" and then "New Products". There is not a price, but the cost is $110.
The puller is under "Accessories".
Jerrod Gross
#1414, May 19,1999
Jerrod Gross
#1414, May 19,1999
Plan on heading to my 1/8th mile track this weekend for their Street Racing night. Get some info back on that later.
The quality of the parts are great. The pulley looks exactly like the original, except smaller. And the puller looks and works like a champ. Made from machined pieces.
Jerrod Gross
#1414, May 19,1999
Jerrod Gross
#1414, May 19,1999
It is a smaller one. About 1/4 inch smaller in diameter (did not actually measure). Yes it fits, barely.
Jerrod Gross
#1414, May 19,1999
Jerrod Gross
#1414, May 19,1999
