Can I add satellite radio to my stock navigation unit?
Old 11-25-2011, 11:55 AM
RoyalAir's Avatar
Hi,
So I have a 2007 Lariat, which came with everything except satellite radio. When I go into "Audio Source" it lists FM1, FM2, AM, CD, Line In, but there is a blank spot where the "SAT" option would go if my truck had it. Is there any way to add satellite to the nav unit? Or do I have to buy a dash mounted kit to get Sirius?
Thanks in advance guys!!
Old 11-25-2011, 09:18 PM
kozz's Avatar
You can add it but need to have your headunit reprogrammed. Adding the SAT is easy but finding someone to do the reprogram.... I used United Radio in NY. They were fast and reasonably priced. The SAT unit I got from a wrecker. If you can't get one from a 07 F150 then you'll have to research other part numbers. There are two different units, terminated and non-terminated. I don't remember which one I used tho. Its an easy one plug install, the SAT unit lives right under the main head unit. Add antenna and you're golden.
Quick Reply: Can I add satellite radio to my stock navigation unit?
