Sirius (non Factory) - Install Confirmation
Just want to confirm before making my purchases..
I have an '06 F150 Harley with the 6 CD factory head unit. It has the Aux button, but no Sirius satellite factory installed. I plan on purchasing the Sirius Sportster 5 with home and vehicle kit.
Am I correct in thinking that I can buy that PIE Aux adapter kit for the truck, pull the factory deck, make the connections at the back, and then plug the Sportster 5 into the PIE audio out connectors,and off I go?
If that's the case.. can anyone confirm how the trim around the stereo/HVAC pops off? I was playing with it a bit on the weekend, and it doesn't seem like it really wants to come off easily, and I didn't want to break anything. Any advice or diagrams on how to remove this would be greatly appreciated.
Thanks so much..
Thanks so much..
Before you pull it, do you have an output somewhere (aren't the ipod or aux connectors on the top of dash tray?) ? If so, you get the wire that goes from there to the back of the sportster. This way, you push aux, you get clear sirius radio. I know because my dad's 08 f-350 has this and he drives it cross country no problem. If not, I think the PIE adapter would be good. The trim is usually a press and snap clip so pry it off with your fingers gently from the top or a corner.
From what I understand, the '06 model had the Aux button, but not the jack in the tray on top of the dash.. I believe they put the jack in starting in '07.
As for the FM Modulator, many of the posts I read advised to go the Aux method using the PIE (believe around $75 USD) with RCA connectors as this would give much better sound than the FM Modulator.
Sportster 5 has an audio output. Just buy an aux cable and plug that in. Hit aux on cd player and viola, CD quality sound, no need for pulling the trim, unless you want it hardwired, which makes for a cleaner install. If you buy an FM transmitter, then you might need some antenna adapters, chrysler on later model trucks
