Connect SIRIUS dock and play to Sirius Compatable OEM
Has anyone connected a Sirius dock and play receiver to their OEM Sirius enabled receiver. I read about the SIRIUS SC-VDOC1 but it does not explicitly say it will connect to ford OEM. Has anyone done it? or is my only option to put on a whole new vehicle docking kit and antenna? Thanks
That being said we actually do have an aftermarket solution that should suit your needs. It's a very new solution and it will integrate SIRIUS and an iPod into newer Fords, Lincolns, and Mercury (as well as other kits for other makes)
Here is the
iSimple Media Gateway Ford SIRIUS Kit. It will connect to the back or your stereo and use the Gateway to interface with your Factory Radio and the gateway can then translate newer devices and technology to the factory radio.
Then if you substitute the SCVDOC1 for the SCC1 then you will be able to use that for the "tuner" portion so long as you have a compatible radio to put on it.
It's a lot of info but this is a pretty cool option and one of the reasons we joined this place is to get the word out on it. I might even do a contest giving one of these kits out for someone who is excited about it, in return for a review and good pics.
Sounds Great
This sounds like a really neat option. Deffinitly the direction i wanted to go in. I will give it some thought and deffinitly let you know and post some pics if i do it. Satellite radio is awesome but the OEM equipment leaves much to be desired after having the Sportster 5! Thanks for the help!
