05-15-2009, 01:52 PM
2006 Ford F-150
Vehicle: 2006 Ford F150
Question on Sirius Aftermarket Radio
So I had Sirius in my stock 6 cd changer and Im looking to get an aftermarket deck. My truck has the sirius built into the truck with the antenna and tuner and everything and I dont want to to have to buy another car kit for it to get it to work. Is there some sort of pin adapter that can be changed into an audio input? any suggestions on how I can get this to work would be awesome. Thanks.
05-20-2009, 09:50 PM
The stock HU has the Sirius tuner built in. If you remove it, then you remove the tuner. You can use the stock antenna for the aftermarket unit.
I highly recommend installing this gizmo for your aftermarket receiver: http://www.crutchfield.com/p_607SCVD...t.html?tp=6953
It lets you use a dock and play radio but hide it away in the glove box and use the controls on the aftermarket deck. This allows you to have the clean install but the versatility of moving the Sirius tunes to a boombox or home kit.
-Phil
2002 F-150 XLT Sport
4.6L Triton V8, 3.55LS, Tow Package, Power Moonroof, SVT LED 3-rd Brake Light,
Keyless Door Handle Mod., Autolamp Mod., BedRug, Signal Mirrors (a la Lariat),
ARE LS II Bed Cover
05-20-2009, 11:32 PM
Quote:
I always thought the satellite receiver itself was always a separate component. I have the single cd HU in my 2009 XLT and the parts manager showed me the receiver that would have been installed at the factory if the option would have come in my truck.
05-21-2009, 05:05 AM
Garage is empty, add now
Vehicle: 2005 Ford F150 XL
Only drawback to going with a plug and play on an aftermarket or factory radio is the volume control will be much lower, in other words, you'll have to turn the volume up quite a bit to hear the radio.
05-21-2009, 08:16 PM
2006 Ford F-150
Ok so Ill give this a shot and see what I can come up with, Thanks
| 2006 XLT 5.4 | 4x4 | 2.5 AS leveling kit | AS AAL | Volant CAI |
| PHP Gryphon Custom Tunes | Banks Monster Duals Exhaust |
| 17x8 XD Spy's +18os| 315/70-17 Goodyear Wrangler Duratracs |
05-30-2009, 09:28 PM
2005 Ford F-150
Vehicle: 2005 Ford Lariat
I have a aftermarket keenwood head unit and sirius kit in the classifieds
2005 6000#Lariat [B]HAS BEEN SOLD :(
Theres No Replacement For Displacement, 419RWHP/ 456RWTQ 13.6 1/4, Roush I/C, 2lb lower pulley, XCAL2 "Dyno tuned by Mike Troyer", Stiegemeier stage 4 port, Pacesetter long tubes, Magnaflow hi-flow cats & Xpipe, Dual Magnaflow, E-fans, GMS Coil Packs, Stull upper and lower billet grill, chrome halo headlights W/ HID's, HID fog's, 2" leveling kit, Viper 791XV, Line-X, Nitto Terra Grapplers, Chrome MB Blitz wheels, Dual heat exchangers, reflexxion hood
06-03-2009, 04:23 PM
Quote:
Many of the newer Fords have it built into the headunit, surprised the 2009 XLT didn't have that, but most in general it's a separate tuner box like you thought.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
