Go Back   F150online Forums > Audio & Video System > Satellite Radio
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Satellite Radio SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 05-01-2005, 12:37 PM
Garage is empty, add now
Vehicle: 2004 Ford F150
roady2 install in 2004 F150 screw
Looking for accessories for a neat install. I have the factory 6-disc in-dash changer that has an aux button and would love to hook into the aux instead of using fm modulation. Also, would like to hard wire the power and not use the cigarette lighter. Any ideas, links, products?
Old 05-01-2005, 05:00 PM
Vehicle: 2005 Ford F-150
www.myradiostore.com is your best bet. They have mounts, hard wire options, and plenty of other accessories. I don't think you'll find anything on the AUX mod, though. Apparently there is a manufacturer out there who is supposed to have something in the near future, but nothing yet.
Also, www.xm411.com and www.xmfan.com are good sources of information.
Best of luck.
Old 05-02-2005, 12:46 PM
Vehicle: 2004 Ford F-150
I installed a Roady2 in my 04 SCREW. Since there is no way right now to use the AUX input, I used a wired FM modulator. As for the power, since the Roady takes 6V & you can't wire it directly, I used a female 12V outlet (cig lighter) from Radio Shack. It comes with about six feet of wire attached to it which I spliced into the radio power wires. I plugged the Roady's power cord into it & tucked everything in neatly behnd the dash. When I turn the key on the Roady comes on. Pretty simple other than getting the center portion of the dash off.
Old 05-02-2005, 01:09 PM
cool - any hints on removing that removal?
Old 05-02-2005, 01:37 PM
I meant: any hints on removing that center portion?
Old 05-02-2005, 02:14 PM
Vehicle: 2010 Ford F-150
Here is where I placed my Roady2, adn so far no problems...
Click the image to open in full size.
I did the same thing basically as Spargo2, except that I spliced into the powerpoint with the plug that came with the in-line fm kit. Then I added a splitter and i have my Roady2 and Radar Detector wired through the same plug. I did it this way because I wasn't sure which wire was switched power in teh radio harness. One day I'll get back in there and wire it to the radio.
Natural Progression?
Next: 20?? F150 ___ SCrew 4x4
Current: 2010 F150 XLT SCrew "Texas Edition" Ingot Silver (5.4L V8)
Past: 2005 F150 XLT SCrew "Texas Edition" Dark Blue Pearlcoat/Silver (4.6L V8)
2002 F150 XLT SCab Sport Silver (4.2L V6)
1999 F150 XLT Sport Black (4.2L V6 Standard Transmission)
Old 05-02-2005, 03:20 PM
nice setup! Thanks - Hopefully, I'll accomplish it this weekend!
Old 05-03-2005, 07:46 AM
That looks exactly like my install. Nice job. spydrev, as far as removing the center dash section, the best way I found to do it was to open the cup holder & gently pull as hard as I could & work your way to the top. If the center has never been out it can be a pain in the a$$ but it will come off. Do a search on "roady" & you should find instructions on pulling the center. Good luck.
Old 05-03-2005, 10:28 AM
thanks for the tips. How about routing the antenna wire? I heard a lot of folks use the 3rd brake light opeingin on top of the cab, but that seems like a long run thru the interior of the cab. How about along the outer edge, passenger-side, of the windshield? Seems like there should be a hole for the stock antenna feed around there?
Old 05-03-2005, 11:18 AM
I didn't like the idea of routing it to the 3rd brake light. Knowing my luck it would leak. I ran my through the existing hole in the firewall on the drivers side, up underneath the cowl, & under the weather stripping on the drivers side of the windshield. The ant. is mounted above the upper drivers side corner of the windshield. I have yet to loose reception.
Old 05-03-2005, 11:31 AM
Spydrev,
I routed mine through the third brake light, and no problems. It was a long run, but it was easy to tuck it away and I still had a couple feet of antenna wire left.
However, a lot of people here are routing their's through a grommet on the firewall and then underneath the wiper cowl for that "stealth" install. They say no reception problems, and I plan redo mine someday.......
Old 05-03-2005, 02:10 PM
did you have to remove the windshield weatherstripping, or does it just fit into that little groove?
Old 05-03-2005, 04:43 PM
There is a thin flat piece of stripping that runs from the cowl to the roof line. I used a paint scraper to gently lift the edge & routed the cable underneath.
Old 05-03-2005, 06:19 PM
cool - thanks for the help!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
