Go Back   F150online Forums > Audio & Video System > Satellite Radio
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Satellite Radio SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 03-26-2005, 07:50 PM
2011 Ford F-150
My Garage
Vehicle: 2011 Ford F-150
XM Install done, Plus a few questions
Well I finally have my XM radio completly installed. So far I have added a Bracketron custom mount, PIE ALP/Ai-Aux, Radio Shack Ground Loop Isolater, several chunks of skin, blood spots and a few cuss fits. So far I like it. I already had an Alpine head unit and 12 changer installed, so I found the PIE interface unit to splice into the Alpine Ai Net. This nifty little box goes in line in the cable that runs from the CD changer to the head unit. It interupts the signal from the changer with the XM signal, when the XM is on. Turn off (or mute) the XM and the changer comes back. This gave me noticeable sound quality gains over the FM modulator, plus it eliminated the static that I was picking up. HOWEVER, it gave me a nasty buzz whenever the key was in the ON position. The buzz was worse with the engine running and would change pitch with the engine speed. Because of this I added the Ground Loop Isolator (P/N 270-054 of Radio Shack). This removed the buzz. I also mounted the antenna above the third brake light. I picked up that tip from someone here but I forget who, thanks anyway. Now I am left with one more thing to finish. I want to hardwire the power supply so that I can get rid of all that wire in the middle of the dash. What have you folks done. The big issue is the voltage, the truck supplies 12-14.4VDC the SkyFi 2 needs 6.0VDC. Is there a voltage converter out there that is small enough to fit under the dash, that does not cost beau coup bucks?
Here is a pic of the final install, minus the voltage converter. What do ya'll think?
Click the image to open in full size.
There are more pics in my gallery.
Joe
Joe
2011 Platinum Ecoboost, 2001 VW Jetta 2.slow, 1986 Porsche 928S
Quote:
Originally Posted by Jeremy Clarkson
A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.
Old 03-26-2005, 07:59 PM
Garage is empty, add now
Vehicle: 2002 Ford F150
Send a message via Yahoo to Patsfan05488
WoW the way you mounted that looks Sweeet . I wish I would have thought of the bracket idea when I put mine on my dash ( around the same spot ) I know if I ever take my mount off it will peel the dash ( 3m mount that came with mine ).
I like that ALOT ,
PatsFan
2002 Ford Scab 4x4 XLT. 5.4
Used to be all white .
Two-toned it with AZ. BEIGE
1715 SC Tuner
k&n FIPK
Magna-Flow SI/DO SS Catback System.
MICHELIN LT 265/75-16 Tires.
Silverstars 9005/9007 and corners
Clear Headlights and Corners
Old 03-26-2005, 08:39 PM
2011 Ford F-150
My Garage
Those 3M mounts are a pain to get off. Your best bet is to use a hair dryer. Get it real hot, then it will just peel off. Be careful, that was one of my cuss fits. I burned my fingers, because the plastic was so hot.
Joe
Joe
Old 03-27-2005, 10:15 AM
Vehicle: 1997 FORD F150
I haven't put a mount in my F150 yet but have it in mine and my wifes Explorers. I bought adjustable cellphone brackets from Walmart that have the same mount as the XM base. The bracket allows you to swivel the face to just about any postion you could want. I use the seperate modulator that you have to wire inline with the antenna, no engine noise or buzz here. I run the sat antenna up inside the rubber door gasket on the passenger side and put the magnet over the windshield about 3 inches over. I have all ove my wires zip tied to the mount and the mount sit near the body line in the dash, I pulled the wires between the panels, you don't really see them unless you are looking for them. I have had XM in my last 5 or 6 vehicles all set up the same way.
Old 03-27-2005, 04:59 PM
Vehicle: 2004 Ford F-150
For your power problem, get a 12V socket (cig lighter) from Radio Shack. I used one with a socket & about 5ft of wire on it. I tapped into the the radio power wire & tucked everything in behind the dash. Now all the wires are tucked away & the sat comes on with the key. Hope this helps.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
