Go Back   F150online Forums > Audio & Video System > Satellite Radio
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Satellite Radio SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 02-04-2005, 05:25 PM
Garage is empty, add now
CD Aux MyFi
I want to Car Toys today and asked them to hook the myfi directly into the radio. They said the only way is to disable my cd changer.
1.) Is there any way around this for a direct signal?
2.) When they say it will disable the cd changer does that mean it will not play cd's at all?
2004 f150 with 6cd changer oem.
Old 02-05-2005, 02:34 PM
Vehicle: 2005 Ford F150 FX4
Re: CD Aux MyFi
There is an FM modulator you can get that goes in-line with your antenna. Best Buy carries them. It works great with the MyFi I have. You just set it up for any of the FM channels listed.
So it sounds if either you don't want to use the modulator or they are not familiar with the MyFi.
Old 02-08-2005, 08:24 AM
I think you're right on both accounts. I'm not that pleased with the built in FM modulator. Even though I've searched all of the frequencies in my area I still hear an unacceptable level of static. Thanks for the tip on the in line fm modulator. I wonder why they didn't offer that up? Probably because they didn't know about it.
Thanks.
Old 02-08-2005, 10:34 AM
F150online
Administrator
2005 Ford F-150
My Garage
Vehicle: 2012 F-150 King Ranch
I had the same problem with my MyFi...
There's a load of information in THIS THREAD.
Old 02-10-2005, 02:34 PM
Vehicle: 2001 Ford F150
halobiont, you might want to check out PIE.net They have a unit (X3) for 97-2003 Fords that connects between the external changer and the radio. It makes available 3 additional RCA inputs to your radio. The only problem I discovered was you had to have CD in the player and be playing it. They (PIE) said that's the only way to do it with the X adapter. They have another adapter that replaces the external CD player and give you RCA inputs for your XML radio (FRED-AUX). Since I replaced my OEM Ford head-unit with the Mach MP unit, I hardly ever use the external changer so I'm going to remove it and use the PIE Aux unit.
go here for a possible solution. http://www.pie.net/aux_ford.htm
Oh, the guy's at PIE were very helpful.
Hope this helps.
2001 F-150 SuperCrew 4X4 LT – Silver w/Medium Graphite interior,
4.6 V8, 3.55 Limited Slip Axle, P265/70R17 Cooper Tires
17” 10 Spoke Aluminum Wheels, Class III Trailer Towing Pkg.,
Remote Keyless Entry, Dual Media Vistieon MP3 & 6 CD Changer,
Captain’s Chairs, Ford Cab Steps – Black, Engine Block Heater
Custom Dual Exhaust with X-Pipe, EGR Carbon Fiber Hood Shield ,Window Vent Shades, Superchip, Airaid Intake System, A.R.E. LSII Hard Tonneau cover with remote lock, Python 1500 ESP Security System w/remote start, Clear Corner Lenses, Rhino Liner, TruckVault, Infinity Kappa 50.2cs in front door, Infinity Kappa 572.1cf in rear doors, Valentine One w/Laser Radar Detector & Concealed Display, J&J Stainless Grille Insert, Pop-Lock in tailgate, 2001 Lighting Tails, Lighting Headlights, PIAA 1451 backup lights, Rockford Fosgate 400a4 & 100z2 Amps., MTX 8" Sub in Expy center console, Cobra 75WXST CB., Remote entry keypad, FactoryTech Transmission Main Control, Mag-Hytec 4R70W-DD Transmission Pan, MyFi 2Go XM radio, BellTech 3/4 drop kit, Wolo Air Horns.
Old 02-13-2005, 09:04 PM
Thanks for all the help.
I installed the inline fm modulator from Best Buy today. It was easy to install and works great. I'll check out the PIE solution also.
Old 02-13-2005, 10:25 PM
F150online
Administrator
2005 Ford F-150
My Garage
Glad it worked out for you Halo... you're right. The install is VERY straight forward and simple...
Enjoy your MyFi! I know I do!
RP
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
