EcoBoost Track Times!!!
Old 09-26-2011, 03:55 AM
Ldecharmoy's Avatar
Post up your 1/8 mile and 1/4 mile times....
I only have 1/8 mile time, last night was my second time running the truck
Old 11-30-2011, 12:24 AM
VETTKLR's Avatar
I bet that 2.1 60' felt like a rocket ship taking off!
Nice time!
Old 11-30-2011, 12:29 AM
coobies5's Avatar
that trap speed is about as fast as mine when i do the 1/4 hahahahahaha
Old 11-30-2011, 07:10 PM
twinskrewd's Avatar
Not bad. How's traction? I have slicks and traction bars and pull a 1.7 60' which is neck snapping. If your not hooking you may want to give it some thought.
Old 12-04-2011, 01:24 AM
Mark Miller's Avatar
My best times so far 9.44 at 73.58 mph in the 1/8 mile,14.76 at 92.13 mph in the 1/4 mile with a 2.10 60 ft.Those increments were all on the same pass 2011 F-150 Supercab 4X4 EcoBoost,3.55 Ls Axle .
Later Mark.
Old 12-05-2011, 07:36 PM
Ldecharmoy's Avatar
Forgot to post up my new best, was at a mustang event and I was keeping up with the 4.6 mustangs lol
Old 05-17-2012, 06:43 PM
hydro1's Avatar
Great times. Are you leaving on a boosted launch? What are your truck specs (4x4, 3:73) etc..
Old 05-21-2012, 03:29 PM
Ldecharmoy's Avatar
yes and my truck is 2wd with 3:55
Old 05-21-2012, 10:09 PM
VETTKLR's Avatar
Awesome!
Old 07-08-2012, 03:30 AM
Ldecharmoy's Avatar
NEW BEST!!!
File Type: jpg
Old 11-19-2012, 11:54 PM
Dmckinney33's Avatar
So when you drag do you start in 4wd then Switch back to 2wd ASAP? Also do you turn traction control and assist off?
Never done much dragging but have a few people that are curious what the e boost will do, want to do it right! Thanks-
Old 11-23-2012, 02:16 AM
hydro1's Avatar
You leave it in 4wd all the way down, but Ldecharmoy has a 2wd. Leave traction control off and brake boost to about 2000-2200 rpm and let her rip. Stability control ( if you hold the traction control button down for 4 seconds) does nothing for straight line running, so don't worry about disabling it. It only kicks in if a massive side to side sway occurs. Traction control takes power out and applies ABS as needed. So just a single push of the button will do the trick.
Old 11-25-2012, 10:30 PM
Awesome! Thank you!
Old 11-26-2012, 11:29 AM
twinskrewd's Avatar
Have you tried launching without holding the brake and gas? This allows the torque converter to flash producing a much more powerful start. Hold the brake lightly enough at the line to prevent the truck from rolling, third yellow light let off the brake and simultaneously slam the throttle to the floor.
Old 12-04-2012, 07:24 PM
JustA5.0's Avatar
Those times are pretty amazing compared to mine. my best so far was 9.7 with my set up.
Quick Reply: EcoBoost Track Times!!!
