The Lightning guys do a lot of racing and they're running some pretty awesome times...there are also some pretty hot single cabs running some good numbers as well...And, I've seen some posts were some supercharged extended cabs and super crews will put it on you, if you don't bring your "A" game...
Jet Stage 3 chip//Throttle body spacer//AF1 air intake// Mac performance MAFS//Y PIPE// NO catalatyc Converters//Gibson dual exhaust//CERAMACOATED HEADERS!!//CAM/ POSITRACTION UNIT //410 gear ratio//NEW Transmission upgraded W/different gears and more holding power//Centerforce Stage II clutch//Centerforce light weight flywheel// Centerforce throwout//bearing//HURST SHIFTER KIT//My homemade cold air//Shaved heads//Upgraded Injectors/Water pump//REAR drop shackle//FRONT Lowering springs and Nittro drop shocks//
75 SHOT OF NITROUS//
And 17.9 in my screw.
this truck is pretty much stock.
Flow Masters//22''rims//fiberglass Bed cover//Nice sound system
Im running a 1988 f150 long bed. It has the 5.0, ford racing underdrive pulleys, MSD ignition, flowmaster exhaust, summit racing gear-drive, 4:30 gears, lakewood tracion bars, and a 100shot of nitrous. I havent done nething else to the engine, BONE STOCk, the key is timing.
Only made 1 run but didnt have enough nitrous, should have filled but before i went to the track.
Runs
60'- 2.100
1/8- 9.48
Speed- 71.08mph
Its pretty exciting staging next to a 5.0 mustang and being able to blow the doors of off it. I am ordering the edelbrock intake, heads, cam, and headers. I am also going to swap out the stock suspension and get some hoosier slicks, hopefully ill get into the 7's so i can add a role cage!!!
How did you get those times in a screw type truck?
The stock lightning hits that... What type of supercharger does the harley have? I want some type of set up like that for my SCEW truck. It's good for a daily driver, but just needs a lil more power. You know?
Actually I've raced a few stock Lightnings and never lost to one yet. My HD is quicker than a stock L and weighs just over 5600lb with me in it.
As far as mods go, I have a 6lb lower pulley, JLP Ram Air induction kit, TR6 plugs and the tuning is by Troyer Performance (with an Xcal2) The blower is the standard Eaton.
I also have LFP 58" traction bars and the run was done on Hankook 295/40/20 street tyres.
I've had a few people call me out on this one so here's a video of the run. You can hear the blower screaming over the music on the P.A. system
I thought the HD was the same weight as My F150 around 7000 lbs or more...
Thats really impressive for a larger truck.
You got to lay off them Twinkies.
How big a boy are you?
Lmao.
i had my truck on the scales at the local dump weighed in at 4800 with my lil brother. he weighs maybe 170.
So needless to say those scales were a tad off. I really want to get on some acurate trucker scales sometime.
-Patrick
__________________ Jmod... 3/5 Drop... Tint 15%F 1%R... Dynomax BulletDual 16" Efans
P&P TB/Plenum... L HL/Corners... Custom Sub BoxReverse Fogs jamzwayne : I'm not saying dont get any hoopie patch for your dang-dang scott1981 : Fly your American flag, but dont let it block the view of your toyota. gators241987 : Chris Hansen is a coc.blocker jbrew : 5fours are notorious for leaking up front @ the water jackets
I weighed my truck on the NHRA certified scales at Houston Raceway Park when I first had it over there.
It weighed 5590lb exactly but this was before the traction bars were fitted.
My truck had a bedcover and bedliner so that's a few extra pounds there.
