After discussions with the 'higher ups', it appears that our dbase backs up on an hourly basis. So, while that may cause a tiny bit of lag, I'm told that it really shouldn't be noticeable on the forum level from a page load standpoint.
Because of this - and the lack of apparent problems on the IB servers - I'm really thinking that it's one of the ad servers causing it... The load balancers are seemingly humming like tops.
You guys that are seeing the lag, are you able to see the ad servers loading?
No, I have pop up blockers in place. It was really bad from about 8 till 11, central time last night.
Flowmaster 40, K&N dropin, Tint, Roush wheels, 305/50/20s
Edge Evo with PHP custom tunes, GF 2" shackles
Sometimes I notice on the bottom ad items that have not finished loading, but lately there is nothing since nothing loads at all, pages are completely frozen when it happens.
Not sure if I have the same problem, probably not. Very slow loading and it even locked up. That was with explorer. Fired up the Safari browser, -back in business.
^^ same here... that was happening all today. Seems ok now on IE (knock on wood)
John
Thanks Watson91 at S-FX
PTM Century Tonneau
Remote Start 14" si/do Magnaflow 45'd behind rear tires
4" x 18" SS Tips
Roush Grille
Billet Bumper Grille
PTM Mirror caps
DVW Intake w/ K&N drop in
Quote:
Originally Posted by 05RedFX4
Best of luck to you, and hopefully you don't have the same attitude when you go into the dealer to get your trans fixed, because if you do your gonna need a big jar of vaseline cause they are gonna stick it to you, HARD
Please post here if and when you're having these problems. Within your post, be sure to include forum and time of your problem (include your time zone).
Something to look at - we are having similar issues on our PC forum, which also uses vBulletin. We have tracked it down to a memory leak. The only way we have found so far to fix it is either restart Apache or reboot the server, we haven't found the actual cause of the leak.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
