Go Back   F150online Forums > F-Series Trucks > Pre-1997 Models
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 09-11-2002, 01:48 AM
Garage is empty, add now
Vehicle: 1995 Ford F150
Attn: ENGINE BUILDERS!!!
If you do any engine building, you need to read an excellent article I found recently. it goes into great detail about crankshaft thrust bearing failures, the causes, and how to prevent them. It is the single best article i have found in years! If you work on engines, or have ever been told that your torque convertor ruined your bearings, you must read this Killer Article!!!
Enjoy!
Take care,
~Chris
Webmaster:
Rice Haters Club
My F-150 Gallery
'95 Eddie Bauer F-150 SC SB / 4.9L / 5spd / 3.55 LS / K&N FIPK w/ Ram Air / JET / Crane / Taylor / Comp Cams / Edelbrock RPM / Hurst / Add-A-Leaf / Bilstein / Bridgestone Dueler A/T Revo 31x10.5R15's / Auto Meter Sport Comp Vac, Volt, Water, Oil & Fuel PSI / K.C. / Optima Yellow / Alpine / Apple / Toshiba / Boston Acoustics / Polk / Bazooka / And more...
Old 09-11-2002, 08:42 AM
Vehicle: 1992 Ford F-150
Send a message via AIM to Ford4ever
Excellent article. Down towards the bottom of the page it says that a pressure regulator spring in the tranny that is too heavy will exert extra force on the thrust bearings. Does that mean that when we install shift kits to raise the line pressures for firmer shifts we are risking damaging the engine?
-Jon
Old 09-13-2002, 03:43 AM
Excellent question! I can't say for sure, but it would lead me to believe that just may be the case.
Hmmmmmm.
Take care,
~Chris
Webmaster:
Rice Haters Club
My F-150 Gallery
Old 09-13-2002, 04:34 PM
Vehicle: 1993 ford F150
Send a message via Yahoo to inski21
the article does point out some interesting things. Now all we need is some pointers for rod bearings. I personally have never seen thrust bearing failure, but I don't build race cars either.
Filing the bearing seems kinda tricky, especially for a driveway mechanic who might not be measuring everything. I have been successful only measuring endplay and plasti-guaging.
Internal combustion engines don't last forever, 2 many moving parts. One in 7 jobs in the US are automobile industry related.
-Chris, the other one
93 XLT StupidCab 5.0L 4x4My Truck Pictures
Rice4lunch
Old 09-13-2002, 06:50 PM
2005 Ford F-150
Vehicle: 2005 FORD F150
It was some good reading.
Old 09-16-2002, 11:05 AM
I sent them an email with my question about shift kits, apparently most trannies have a convertor pressure regulator so shift kist won't do any harm. This is the email i got from the CEO of the company:
Anything that raises converter charge pressure will increase the load on the crank thrust. Adding a Shift Kit does not in itself cause this. After all, there are thousands of cars driving around with Shift Kits in them. If your transmission has a converter regulator system in it (I'd have to know what type of transmission you have to answer this question) then it doesn't matter; increasing line will have little affect. A bigger issue is resistance to cooler flow. Clogged lines, kinks in the lines, a clogged cooler, too many coolers, etc. play a very big role in
this.
-Jon
Old 09-18-2002, 06:32 AM
Excellent info! Thanks for asking him, and for posting his reply!
Take care,
~Chris
Webmaster:
Rice Haters Club
My F-150 Gallery
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
