Axle Codes Simplified (?)
#33
Now I don't think that's 100% accurate. This past winter I pulled out my budddy in his 2004 Camry. Which weighs about 3000-3500. That was in snow, with rwd and 2.73's. I had no issue at all pulling him out. Just a little tire spin.😂
#34
You responded to a post from 9 years ago.
Those particular ratings are because of the Mazda manual transmission. The I6 has plenty of torque to tow heavier and the chassis is plenty strong, but you will break the transmission if you make a habit of it. It has a weak input shaft and was designed for a lighter vehicle with a less powerful engine.
#35
re:
X143 means it's a F-150 4x4 w/ a 6250 lbs. GVWR and a 139" wheelbase
139 confirms the wheelbase
GJM means it has a cloth split bench seat, and that it's a styleside supercab
I don't show a listing for a "T" trans.
P means that if it's tutone, it's supposed to be "Tobago Green/Oxford White"
D7 just tells what part number the springs are.
19 means you have 3.55 gears, but both your front and rear axles are non limited slip.
Take care,
-Chris
Take care,
-Chris
HI Chris on my 1990 ford f150 xlt lariat supercab this is what it said on the Vin tag 139...139" wheel base GMB x151, trans: E, 19 nothing for tape Please tell me what I have for my truck and it's 4x2 thanks
#37
