EGR Problems 95 f-150 - F150online Forums
Old 02-07-2002, 01:09 AM
My 95 5.0 f-150 pings terribly on light throttle. Because of this, I had to lower the timing way down. It runs like a dog with the timing way down, so I would like to correct this problem.
I hooked it up to a scanner and got an "insufficient EGR flow" code. 332 I think. What could be restrciting the EGR flow? It has a brand new EGR valve on it.
Thanks,
Scott
Old 02-07-2002, 11:03 PM
lack of vacume. check the vac. line's. see if they are ok. start there. good luck
Old 02-07-2002, 11:09 PM
thanks alot,
I found a cracked (hard plastic) vacuum line that goes from the "tin can" to the intake. I think I'll just buy a section of rubber vacuum hose and replace all the hard plastic lines following the diagram.
scott
Old 02-07-2002, 11:15 PM
I forgot to ask...Could a plugged cat cause this code? My cat rattles all the time and I also have the 311 code. (Thermactor pump inoperative) so i'm assuming my cats are toast. I know that could be my power problem...
scott
Old 02-08-2002, 08:43 PM
i am going through this now on my 90' . i have a plugged vacuum line from the evr to the egr . check the vacuum to the evr from it's source if you have it there then check the line from the evr to the egr for cracks or blockages .
Old 02-09-2002, 03:06 AM
same problem
thats same thing happened to me,I was freaking out untill I saw that little red vacum line melted in half....I just did what you said and patched it with rubber tube....works fine now.
Old 02-09-2002, 09:46 PM
Thanks for the replies. I replaced all the hoses, and found 2 broken lines. It seems to be working now, and the check engine light doesn't come on anymore.
Thanks again
scott
Old 02-17-2002, 08:46 PM
pluged exhaust should not cause a lack of egr flow. on 95 i think it still use's evp. so it just know's if egr open's or not. and how far it does. a plugged exhaust will cause lack of power. and if it get's to that point. it will cause alot of heat build up and start cracking your exhaust maniflod's. but you should notice the power lose if it is starting to plug up on you.
Related Topics
Thread
Forum
Replies
Last Post
Russell04fx4
V8 Engines
2
08-06-2015 10:45 AM
kev2126
07-25-2015 11:30 AM
F-150 tRUCK
2015 - 2017 F-150
0
07-22-2015 07:41 PM
omegaman1955
V8 Engines
13
07-16-2015 08:58 PM
kolik
07-10-2015 11:04 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
