Exhaust flange stud/nut torque?
You just put the stud in tight enough so it won't vibrate out. Then you install the y-pipe and tighten the nuts; so that they're tight. You're not trying to see if you can snap the studs, you're just making it tight.
Never saw anybody use a torque wrench for those; but I suppose it would be about 35 ft lbs, if that.
