Tank Selector Fuse / No Cruise Control
I have stock '86 F150 with 184K miles, 5.0L engine, and auto trans. About two years ago, I had both fuel tanks and the fuel selector valve replaced. The fuel selector valve has worked since the replacement with no issues. Yesterday I was checking the fuse panel in trying to find why the cruise control would not work. The owner's manual showed a fuse for the valve selector switch but the corresponding slot in the fuse panel is empty. As stated above, the valve selector switch works so should I put a fuse in the empty slot in the fuse panel or leave well enough alone? Secondly, I was able to locate a fuse for the cruise control and that fuse appeared to be good. What is the next step in troubleshooting the cruise control not working problem? Thank you.
Speed Control, look this over if you don't have..
http://www.garysgaragemahal.com/speed-control1.html
