1987 f150 XL No starting or cranking
Old 10-22-2016, 10:52 PM
jmendoza7301's Avatar
Im having trouble figuring out what is wrong with my truck. It wont start, wont even crank or click. I change battery, solenoid and starter and still not even a click. But my lights and gauges work...please help...any ideas on what to check next?
Old 10-27-2016, 08:58 PM
1995XLT's Avatar
Check all the electrical connections in the starting system heavy gauge wires - both ends including the ground. Check that you have power coming to the little push-on wire on the fender mount solenoid when the key is turned to start.
Old 10-27-2016, 10:48 PM
Thank you for your suggestions. ..i will definitely check it. ....i really want to get this old truck going again. ..
Old 10-28-2016, 09:30 AM
MKTRUCK's Avatar
Check and make sure the transmission is in neutral or park. I had the linkage pop out out at the transmission. Lever shows park, but at the transmission it's still in gear.
Old 10-28-2016, 10:23 AM
glc is offline
Neutral safety switch?
