manual trans oil
manual trans oil
94 f150 4.9 5spd
I changed out the oil in the manual trans with motorcraft mercon lv this last fall and it is getting increasingly rough between first and second. I thought I read right but need to be sure if it's right. I also read elsewhere Pennzoil synchromesh could help.. any ideas?
Thanks Craig
Thanks Craig
I picked up the mercon V and got to thinking I put that same mercon LV in the transfer case it's 4wd. am I OK on that or should it be the V? I appreciate the help. Craig
The only F150's the LV should be used in is the 6R80 automatic transmissions starting in 2009. It's too thin for either your trans or case.
This is what you are supposed to be using in the transfer case:
The manual trans was speced out for Mercon, which is no longer available, Mercon V is acceptable.
Amazon.com: Genuine Ford Fluid XL-12 Transfer Case Fluid - 1 Quart: Automotive
Craig
94 f150 4.9 5spd
Thanks Craig
Thanks Craig
I just replaced my flywheel, clutch, pressure plate and slave cylinder (all LUK Band) and did the oil change as well.. The oil that was in it looked really dirty.. I added about 4 quarts of Mobil1 Synthetic ATF. It's been about a month and the gear change is real smooth. I would recommend it. Each quart was about $10 at AutoZone. Hope this helps.
