Dizzy 1996 f150 4.9 liter
I'm not sure what you're saying. There is an allen wrench type hole in the very bottom of the distributor that I think drives the oil pump, If your new distributor doesn't have this it won't work. You will probably need some kind of puller to get that drive gear off that the roll pin was holding on. When you put that gear back on the hole that the roll pin goes in MAY be slightly offset so the gear MIGHT only go on one way.
Again I'm not quite sure what you're saying. And yes I read your latest posts up above in the V6 engines part.
