Timing issue?
Timing issue?
I have a 1984 F150, 302, stock except for the new Edelbrock carb and intake I put on after the 2 barrel went caput. This engine was making a lot of HP at he low end before I made change, but ran good. Now in the upper rpm's it does not get sluggish but I am getting, well it sounds like back fire. So I figured now that I have opened up the air flow, I am making more HP in the upper rmp range and the timing was not advancing enough to keep up. When I advance the timing, it gets rid of the back fire, but I loose some low end HP and get pinging. Got a full rebuild in mind to make good use of the new 4 barrel, but until then any suggestions?
Timing issue?
When I saw your post, I was thinking, what is that! Take the 302 out and put in a 400. But after that I looked at the link and I will give that a shot. More fire may be answer to my issue. Had not thought about that since I had not replaced cam or anything like that, but it makes sense now.
Timing issue?
O and thanks for the info. You would not happen to know how new of a seat I could put in this 84 do you? I do not know what year they changed the floor pan or if they even have. Would like to upgrade seat from bench seat to one of the newer 60/40 splits without having to do too much work!
