8.8" build/upgrade suggestions
I have a 92' F150 with 8.8" 3:55 & LS.
What would be recommended to build it as rugged as reasonable and best option to eliminate the c-clips?
The one thing that I like about the 9" is it doesn't have c-clips. But Strange and Moser have c-clip eliminators. Is there any problems or issues to using c-clip eliminators?
Will be regearing to 4:10, limited slip, heavy duty 31 spline axles & welding tubes to center.
Strange has 31 spline with 1/2" studs and c-clip eliminators and 4:10 ring & pinon. But don't know anything about them other than what read on their web site.
I know some will say c-clips are fine, but it just bothers me that if some how I snap an axle my wheel & truck will part company, how ever unlikely it might be. lol
If I use 31 spline axles I can use the factory LS for a while so can put $ into other stuff on truck for a while.
Doing SAS on front, but will build all of it that I can, but some things need to be measured before ordering. In a few days after I get things figured out what I want to use for the SAS, I'll post it up here & get some input on my intended components.
Whose axles & ring & pinion would recommend? Anything else be recommended to do for the 8.8" rear? It's not really going to be a hard use rig, but want to have it as strong as reasonably can be made.
Edit: Found out Dutchman makes a 9" end that is welded in, then uses bolt in axles like the 9" and doesn't then doesn't need c-clip eliminators, which have read tend to leak. Going to check them out.
Strange axles aren't intended for truck & off road use, I found out.
Cheers, Allen
Cheers, Allen
