Check Engine Light / Won't Shift ???
I have a 1995 F-150 extended cab with just a little over 200K. 5.0 / automatic trans.
This truck has had several issues, I just bought it. Throwing codes for TPS, EGR, etc...
I fixed all the issues and codes except for one nagging problem. The truck runs great when it's cold. Once it warms up, when I stop the truck and turn it off, upon restarting the truck the check engine light comes on and the truck won't shift out of first gear. After a short period of time, maybe one to two minutes, the light goes out and the truck runs and shifts great until I turn it off and restart the truck, then it duplicates the problem.
The light won't stay on long enough to grab a code. The truck runs super good unless you shut it down, restart and head down the road.
I tried to manually shift it, but only had 1st and 2nd gear until the check engine light goes out.
Any ideas?
Any ideas?
on
You haven't described the truck nearly enough. Click this & read the caption:
http://www.supermotors.net/registry/media/72354
Codes don't identify parts - they identify FAULTS, so don't pick a word or 2 out of the definition. Read, understand, & post each code's number & its COMPLETE definition. Preferably from several lists. Mine is in this caption:
http://www.supermotors.net/registry/media/245234
It's long, but read the whole caption, which includes a TSB about CEL with no DTC. But just because the CEL goes off, that doesn't mean the code is gone - the DTC stays in memory until cleared, or for ~100 key cycles.
If the fault affects the transmission, expect to see some 6XX codes. This shows how the E4OD works, and the 4R70W is very similar:
http://www.supermotors.net/registry/media/704885
Finally: how are the cruise & speedo?
http://www.supermotors.net/registry/media/76023
