questions aboit bolting up
Old 05-24-2015, 08:58 PM
gotahaveanswer's Avatar
Ok so I just bought a 93 f150 with a 302 in it. It is a 4x4 the automatic transmission is not functioning at all no reverse no forward gears. I have a 2wd 89 f250 with a 300 in line 6 will they bolt up? Or will the transfer case cause trouble for me? Please need knowledge
Old 05-27-2015, 09:55 PM
adrianspeeder's Avatar
Nope, need a 4x4 tranny to have a place to bolt the transfer case to as well as a splined shaft vs a yoke output.
Your choices of 1993 trannys with the 302 would be an E4OD that has a shifter display PRN(D)21, trans code E on door jam sticker, and 20 pan bolts, or an AOD with a shifter PRN(D)D1, trans code U on door jam sticker, and 14 pan bolts.
Adrianspeeder
Old 05-27-2015, 10:34 PM
Thank you very much! I appreciate the knowledge! I think I have solved my problem though. I bought a 91 f150 with a 300 straight 6,automatic transmission and is 4x4 as well. He says the only thing wrong with it is it has a cracked block. Which is a nightmare. But I only need the trany and am glad to keep it as a parts truck.But when I go to change out the transmission is there any gaint warning signs I should look out for? I am a 'shade tree' mechanic I know most of what I am doing haha
Old 05-28-2015, 01:36 AM
glc is offline
That may not work. The 91 300 is going to have an E4OD, and will only work if your blown tranny is also an E4OD. The E4OD requires a computer, the AOD does not.
Quick Reply: questions aboit bolting up
