'82 F-150 - turn key, nothing happens
This truck is a recent buy. I didn't know a whole lot about it, but the seller basically gave it away. It's a 1982 Ford F-150 Step Side with a 302 V-8. There are some after market parts. I replaced the ignition coil because it would start and run fine, but would die after a while when the motor would get hot. This fixed the problem for the most part. I went out today, and it started just fine. However, very soon after it started everything just shut off. No power to anything. I turned the key to off, waited a few seconds, and turned it back to start. Nothing happens. It doesn't turn over. No lights on the dash or in the cab turn on.
I am by no means a mechanic. I have done some light work by guidance. Any ideas on where I should start with this project? Could it be faulty battery cables? Ignition switch? Any advice will be much appreciated!
