1995 Filler neck question
It depends on the length and shape of the rubber hose. If it's real short it will be much harder to do.
There is also a vent hose you might want to look at in the same area I believe.
If your leak is coming from the hoses them that should fix you right up. If it is leaking around the metal flange on the tank from rust or a crack, then you need to replace the tank.
UNDER NO CIRCUMSTANCES SHOULD YOU ATTEMPT TO WELD OR SOLDIER THE GAS TANK!
The truck is currently in the shop for a long time. Its a 95 so shop said it was looking for some obsolete parts which he finally found. They were sorry it was taking such a long time and I mentioned the leak and said if it was the rubber hose area they will fix it for free. But I mentioned that if it was the filler hose or something else, they will let me know and I can figure out how I can do it on my own. At least it'll be on a lift and they can see it completely well not like I can in a driveway.
Thanks!!
