loose steering
The 92 has the TTB, correct? The radius arm bushings will make it steer weird.
A less than reputable shop will sell you an alignment with the parts that Pizzaman listed needing attention, then when you complain change them and charge for a new alignment, hope this isn't the case. Also if the toe in isn't right it can make it feel either loose of like something is dragging.
Did the alignment shop mention any parts that need attention?
