fuel pump?
fuel pump?
So i went to lunch came out and my 1989 ford truck wouldn't start. After my husband proceeded to try and start the car 150 times it finally started getting angry at him and making one hell of a noise. i got out to look under the hood and found out that the pullys had seized up. So i loosened them and proceeded to try and start it. after hitting things with a hammer and generally being way over my head i just happened to come across the fuel pump relay that looked really burnt out and in bad shape. So i replaced it. Needless to say my truck still will not start and im getting no fuel through my lines. I have two tanks on my truck and im pretty sure the fuel pump is toast. Do i have one on my back tank? How can i fix this headache of a problem? It is fuel injection but im not really sure if my fuel pumps are electric or not
Will I be listening under the truck by the tank for a pump sound? With the engine noise, I don't know if I can hear anything!
Can you explain a little bit how this is done? My 95 rear tank is not working. I flip the rocker switch and truck dies in about 30-45 seconds.
