whats it gonna run 1/8 mile??
I'm going back to the track sometime soon.. Wanna hear what some of y'all think the truck will run..
Last time it ran a 10.59. BUT it spun out the whole, was not cooled off, left the line off idle, let the trans shift automatically. apun into 2nd gear, crappy tires still at 35 psi, still had pacesetter shorties, and factory y-pipe and factory cats..
And to do that y'all need specs.. Here I go..
92 reg cab short bed Flareside.
5.0 .030 overbore
Flat tops w/valve reliefs
Trick flow track heat 170cc/58cc chamber heads
Comp cam XE-264hr-14 pn:35-349-8
Scorpion 1.72 roller rockers
Hedman long tube headers
2.5" duals w/magnaflow cats, x-pipe, spintech race mufflers
Rebuilt upgraded AOD, factory stall
3.55 rear gears..
I will be doing the ole AOD shuffle to shift gears manually..
Will be leaving at whatever rpm I can rev it to before it breaks tires loose.. Will be shifting around 5300 which is just right before rev limiter..
What do y'all think?
5.0 .030 overbore
3.55 rear gears..
