code 212 fix
Old 08-28-2013, 08:01 PM
biggreen85's Avatar
code 212 fix
Hey guys i have a 94 f150 5.0 and im having a low rpm miss when the truck getst a sertian temp.... the code im getting is 212 spout circut grounded.... anyone have any tips to get me started fixing it? Thanks for any help
Old 09-07-2013, 09:15 PM
93f150302's Avatar
Bump
Old 09-08-2013, 01:28 PM
adrianspeeder's Avatar
The spout connector is only a disconnect between pin 36 on the EEC and pin 929 on the fender heatsink mounted ignition control module.
I'd start with unhooking the ICM connector and EEC harness, leaving the spout connector in, and shooting with an ohm meter between a chassis ground and the unhooked connector on either end.
Adrianspeeder
Quick Reply: code 212 fix
