1995 fuel problem
Old 08-05-2013, 12:42 PM
dhorn's Avatar
1995 fuel problem
1995 F150 Straight Six 5 Speed. Truck Takes A While To Get Started. No Leaks And Fuel Filter Is Clean. Fuel Pump Kicks On. I Did A Fuel Pressure Test And It Didnt Have Any Fuel Pressure. It Slowly Built Pressure And Will Start. Once It Starts The Pressure Holds 60 Psi And Runs Fine. I Have To Turn The Key Off An On About Ten Times And Crank It Then It Finally Starts. Runs ****ty At First But It Clears Up. There Are No Codes And The CEL Is Not On. Is This A Fuel Pump Problem???Any Help Is appreciated
Quick Reply: 1995 fuel problem
