94 f-150 5.8 all the sudden starting hard ????
Got out of work & jummped into truck it cranks real fast & like 20 times to start, does this on both tanks just put a new fuel filter in , rear tank was done last summer almost seems like distributor ? runs fine once its going, or is it a sensor, tommorrow my brother inlaw is a mechanic & will hook the testers up but just wondering what u guys think it is ? Thanks ..
wow no takers we put fuel pressure on the line & n fuel preesure turn it over 15 times the fuel pressure hits 40 lbs & she fires, but does this with both tanks so both check valves bad ?? R they seperate or do u have to replace the whole pump or pumps I will only do 1 because once it is running & u switch it over its fine ???
turn the key u can hear the pumps run no fuel pressure until it cranks over a few times which your right thats what i thought thats what electric fuel pumps r for right, for that being said is it my pumps ? got to be check valves cause he said there should always be fuel pressure in the fuel rails to prime .....
It bleeds down right away, dealer said there is a check valve in line on fuel rail which my brother inlaw said he only seen the regulator, a fuel regulator will do this ?? thanks for the tips. The service guy said the valve could be half stuck & returning the gas to the tank that is off making it not get fuel presure right away, makes sense also??
Come on guys lets get the brains working, there is a round chrome diaprham looking thing on the blue fuel line going back from top of motor is that a check valve my brother inlaw stills says both went bad in each tank I dont beleive its that & i am noting pulling a tank to find out its not the problem.. adrian you said regulator how could it be that doesnt that just cause too much gas to flow & run rich ?? or is there a valve in the regulator ??? the chrome thing im talking about looks like a regulator but is a lot thinner about 2" wide 1/2 " thick or so ???
