Bad, Bad transfer case noise i think, help please.
Hi all, I'm new. I have a 93 f150 with 35k on it. 5.8 1/2 ton, Auto trans, electric shift t/case, factory auto hubs. It is all stock except for an aussie locker in the rear. Starting a few days ago, when I turn sharp and apply signifigant throttle, i'm sure the front diff engages. Also small brake applications from a stop there is a small noise, hard stops, lots of bad gear noise. Could my t/case have broken a snap ring causing my stack up to shift. I was a GM guy so all this is new to me. It's wierd, I swear my front diff applies when I crank it and hit the gas in 2wd. I crawled under and turned d/shafts, made sure hubs spin free ect. But I can't really lay under it under a hard stop on flooring it and cranking it. Thanks all! The noises and clunk I'm feeling is not the aussie locker.
Here's another post from the OP ,, different thread.
Hello, I have a '93 f150 4x4. Truck has 35,000 miles on it, new stock except aussie locker in the rear, warn premium hubs, and rancho shocks. I searched and checked all the related posts but still can't find my clunk. Some times when I go over big bumbs, or big ruts, but primaraly when I'm turning sharp left I get a huge clunking under the floor board. I swear it feels like the t/case yoke is hitting the floor board(obviously it's not). Every thing is tight, bolts nuts all there, radius arm bushings like new, ball joints ok. I can get it to get real loud on cement going up a hill around a corner if i get into it and don't let the locker ratchet. It's not the locker making the noise anyways. It's like someone is hitting my floor board with a hammer. Any suggestions please?
