New guy needs some vacuum help
Working on an '88 f-150 with the 5.0 engine, had to do a head gasket (previous owner let it sit with just water, all freeze plugs were rotted out) when pulling apart noticed many of the vacuum lines were broken, and/or plugged. The emissions decal under the hood is gone. I have figured out most, but I have 3 ports with nothing, 2 on the ported vacuum switch at thermostat, and one on top of intake. There is one area where 2 hoses are electrical taped together, and lead to the canister, both come from the solenoids under coil. Any help is appreciated.
ok still have some issues, I have a line from the valve on top of the air pump that is broken (tan), and still have a port on the vacuum switch at the t-stat empty, I don't think the tan line went there, the line naturally wants to go towards the rear of the engine. Any other help is appreciated
