how to drain a full gas tank
Old 05-24-2012, 10:10 AM
hughbie's Avatar
Cool how to drain a full gas tank
Good day all,
I have a 1988 F150 5.0 with dual gas tanks. The fuel pump is dead in the front tank but a little while back, the selector valve went bad and the front tank filled up and overflowed.
I've replaced the selector valve and now need to drain the tank so i can drop it to remove the fuel pump and replace it.
So, how would you guys empty a full 'dead' tank?
Thanks in advance.
Hugh
Old 05-24-2012, 10:13 AM
worm5932's Avatar
Id pull the bed you'll need new bolts but its pretty easy.
Old 05-24-2012, 10:17 AM
hughbie's Avatar
Pull the bed and then remove the fuel pump while tank is still in place? What a novel idea....DUH! sometimes i can't see the forest 'cause of the trees.
Thanks Worm
Old 05-26-2012, 07:26 AM
ncranchero's Avatar
By far the easiest !
Old 05-26-2012, 08:45 PM
adrianspeeder's Avatar
Old 05-27-2012, 07:14 AM
ncranchero's Avatar
Don't have to remove it. Just un-bolt and slide it back. Easy enough doing it by yourself.
Quick Reply: how to drain a full gas tank
