new member with trany problems i think
Old 05-01-2012, 07:11 AM
SASQUATCH106's Avatar
i have a 1990 f150 xlt lariat 4x4 shortbed with the 5.0. its a automatic. my problem is i can take off in 1st with plenty of power but when it getts to 2500 to 3000 rpm which is where is has shifted since i have had it it seems to slip out and rev up as if in neutral , after a few seconds 2nd will catch and so on.once it gets to the od its smooth and it will down shift fine too. and reverse work fine too. i have checked the transmission fluid and is fine. so is the trany shot? if so how do i know what trany i have ? door tag has a code t under trans. any help would be great. thank you
Old 05-01-2012, 11:20 AM
glc is offline
Trans code "T" is a light duty AOD. There are no electronics involved. About the only thing you can do is properly adjust the TV cable - and if this doesn't fix it, you are probably looking at a rebuild.
Old 05-01-2012, 05:52 PM
well looks like I'm pullin the trany this weekend. I plan on going to the local you pull it to try for one
Old 05-01-2012, 11:17 PM
glc is offline
Have you adjusted the TV cable?
Old 05-02-2012, 12:24 AM
I'm sorry I don't know what you mean by tv cable?
Old 05-02-2012, 09:27 AM
glc is offline
That's the cable/rod that goes from the throttle linkage to the tranny. There is an exact adjustment procedure.
http://lmgtfy.com/?q=ford+aod+tv+cable+adjustment
Old 05-04-2012, 05:58 PM
checked the tv cable its fine and went to u pull it and could not find a trany so i went to a trany shop and they said my trany has no 2nd gear and 900 for rebuild and converter? anybody got any sugestions?
Quick Reply: new member with trany problems i think
