Go Back   F150online Forums > F-Series Trucks > Pre-1997 Models
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 04-21-2012, 02:36 PM
1995 Ford F-150
Vehicle: 1995 Ford F150
95 model 4.9 manual - Speedometer/odometer failure
For my 1995 model 4.9 manual F150 - the speedometer/odometer stopped working. The Odometer is now a blank area.. The truck had approximately 220,000 miles on it.. Should the odometer/spedometer both fail at the same time?
I checked the fuses and all are good.. With the odometer being all blanks it makes me think it might be something electrical..
Any ideas on where to look next?
Thanks in advance for your help.
Old 04-21-2012, 04:28 PM
1996 Ford F-150
Vehicle: 1996 Ford F150
If you have verified all your fuses, then you need to check your connectors and grounds to make sure nothing is loose or corroded. If the fuses are good, the harness is good and the connections are tight that leaves only the PSOM (Programmable Speedometer / Odometer Module) itself. AFAIK they can only be replaced not serviced.
1996 F-150 XLT, reg. cab 6.5' box, 4.9 I6. E4OD w/ B&M alum sump, auxiliary cooler and external filter, Addco 1" sway-bars F&R, Bilstein shocks, 16 x 8 AR Bajas w/255/70-16s, Line-X spray in liner, hinged tonneau, Reese hitch and electric brake controller, VDO tranny and engine oil temp gages, stainless pushbar, Hella 550 fog and driving lights, Hella backup/work lights, 3.73 Trac-Lok w/ an alum. diff. cover with cap support screws, PFC "Z" brake pads, high flow cat with a 2.5" cat back with a FM 70 muffler.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
