can this radio come out 84 ford f150
Old 03-11-2012, 06:28 PM
84FordF150's Avatar
I have this radio and want to take it out to put a aftermarket one in. Im not sure how to get the radio out or if there are hidden screws. Does anyone have a wiring diagram for this 1984 ford f150.
Old 03-12-2012, 07:55 AM
chrmar's Avatar
I believe if you take the ***** off the whole wood-grain panel should pop out; if not there might be a screw or two somewhere. You'll need to trim the plastic behind the ***** so that the opening is the same size as the chrome surround in order for an aftermarket stereo will fit. If you pick up an installation harness it'll pretty much just be match the colours with the stereo.
Old 03-12-2012, 08:01 AM
MGDfan's Avatar
^^^ Removal sounds about right.
As for wiring, here ya go: http://www.the12volt.com/installbay/...etail/866.html
Old 03-15-2012, 09:16 PM
adrianspeeder's Avatar
This is how I did a '79.
http://www.supermotors.net/registry/17545/60106
Adrianspeeder
Old 03-17-2012, 06:37 PM
fordguy29360's Avatar
yea just remove the ***** and take the screws out of the wood panel and the radio will come out.. Did it to an 82 f150, 84 f250 and a 80 f150
Old 04-29-2012, 11:11 PM
84FordF150's Avatar
the size of the cutout for the radio is a square not rectangle do i have to cut out the dash just to install a radio.
Old 04-30-2012, 06:00 AM
chrmar's Avatar
Yes. Or, get a bezel from an '85-'86 which I believe has a standard DIN size radio.
Quick Reply: can this radio come out 84 ford f150
