94 Cluster swap help
My cluster on the current truck works fine. It was replaced by the previous owner but the mileage doesn't reflect what the truck actually has on it. So I found one with almost the exact mileage to the truck. Did the installed today and all the gauges work fine but the illumination doesn't work for some reason. According to the seller, this cluster is a 94-95 so it should be plug and play. I put the old one back in and it lights up fine. Any thoughts on this?
Everything was clean. I emailed the guy that sold it to me. He said that my part number was different. But should all 94-95 cluster be interchangeable? My previous one was w/o tach and so is the new one. From what I can gather, people have swapped without any issue. Things like the battery light, engine light would work but no illumination.
Man, I uninstalled and re-installed like 4 times yesterday but still no luck. I emailed the guy that sold it to me and he stated that I have to get one with the exact part number as mine to get it to work. It's going to be hard to find one with the same part number for this low mileage. I check over everything yesterday. No corrosion, no loose parts or anything. It got to be with the different wiring or something. I'm just not experience enough to figure it out on my own.
It was fine with the old psom. Not sure why it does this now. All the other gauges are perfect.
