new to the forum
new to the forum
hello im new to the forum. i just picked up a 1992 ford f150 4x4 with a straight 6. i got it from a rancher by my house for free. after putting in new fuel tank, pump, filter, and map sensor it runs fine. what are some cheap mods i can do that wont brake the banck. it is going to be an off road truck. it came with the overload springs on the rear and was wonedering if i should take them off and where do you install an aftermarket temp gauge?
The mounting of the aftermarket temperature gauge will depend if its electric or a capilliary type. An electric can be mounted almost anywhere while the other type usually mounts under the dash near the ash tray. I have seen several guys that mounted a gauge pod in place of the ashtray. If you go with an aftermarket oil pressure gauge use an electric, you don't want hot oil in your cab if the line breaks.
The best way to get the best mileage is to get everything up to tune and minimize friction. There are no magic spark plugs, CAI, or throttle spacers that give higher MPG.
Check the exhaust for restrictions. When I replaced my stock system on a 302 I enlarged it to 3", installed a free flow cat, muffler, and had it exit before the rear passenger wheel. Consider doing the "sixliter tune up" as described on the Bronco forums. Synthetics can reduce friction in the differntials, transmissions, and engine. Driving habits have the most influence on gas mileage, I use a dash mounted vacuum gauge to help. Its also a very good diagnostic tool.
Welcome to the forum and to Ford trucks
rikard
rikard
