Go Back   F150online Forums > F-Series Trucks > Pre-1997 Models
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 01-29-2012, 11:12 PM
Garage is empty, add now
93 harmonic balancer 5.0
Ok first time to attemp harmonic balancer replacement. It seems the rubber that is between the outside and inside pieces have gone away. Now the outside piece just spins and makes alot of noise. Can it be driven this way for a little bit till we get around to repairing or should it be done right away?
How do I replace the balancer? WHat about when using a puller how do I stop the crankshaft from turning?
Old 01-29-2012, 11:38 PM
1990 Ford F-150
My Garage
Vehicle: 1990 ford f150
whatdo u mean by inside n out side are u talkin between the balancer n pully or between the balancer and timing cover
to remove balancer
u remove belt then take the 3 or 4 bolts holding the pullys on the ballancer off and pull the pully off then take the center bolt out then get the puller n just pull it off.
if u use an inpact wrench u woulnt have a problem with it turnin
6 in a row makes it go. big block 6
1990 ford f150 xlt single cab long box 4x2 4.9 strait 6 b/w t18 4 speed 3.55
Old 01-30-2012, 07:08 AM
I guess what i meant was the balancer is in two pieces now there is no rubber between the two , i called them inside and outside rings
Do I have to pull the radiator or is there room to work?
Thanks for your quick reply.
Old 01-30-2012, 09:42 AM
1990 Ford F-150
My Garage
the 2 pieces i am assuming is the pully for the belt ant the balancer and if that u only have to pull the pully. but ive never seen a piece of rubber between them
Old 01-30-2012, 08:54 PM
do i have to pull the radiator or is there enough clearance
Old 01-30-2012, 08:59 PM
1990 Ford F-150
My Garage
of u just have to pull the pully off no if u have to pull the ballancer yes
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
